CFXPost-Help!
Old   May 10, 2005, 06:03
Default CFXPost-Help!
Ogbeni
In CFX-POST, I tried to plot some presuure contours, but the scale are so large they obscure the contours, how can I reduce the size of those scales or better yet turn them off.
Old   May 10, 2005, 07:13
Default Re: CFXPost-Help!
Rui
I don't know exactly what you mean. But in CFX-Post you have 4 options for the range (is this what you mean by scale?) of the contour: Global, Local, User Specified and Value List.
On the Labels tab you may chose if you want to show the contour numbers.
On the Render tab you may check or uncheck the Draw Faces box and the Draw Lines box, on this last one you have the option to select Constant Colouring (and the colour you want).
Regards,
Rui
Old   May 10, 2005, 09:32
Ogbeni
Rui, Thanks, but what I mean is the font size on the scalss, they are so big compared to the contours, I like to turn 'em off or reduce.
Old   May 10, 2005, 09:49
Feng
you can change the font size in Default Legend in View Control
Old   May 10, 2005, 10:06
Rui
In CFX-5.7 and 5.7.1 Post, on the Objects tab open the View Control (click the + symbol) and you may uncheck the Default Legend box. You may also double click it to edit it, then select the Appearence tab and you have some options to change the legend display. To reduce the font size, reduce the value in the Text Height box.
In CFX-5.6 you can do the same things, but you'll find the Default Legend in the Object Selector box instead of the Objects tab.
Regards,
Rui
Old   May 10, 2005, 18:13
Ogbeni
Cheers ! Rui.
How to get rid of ANSYS logo from CFXpost etc Kumar CFX 10 July 12, 2016 01:17
Velocity profile in boundary layer in cfxpost bennn CFX 9 March 26, 2010 15:10
help on CfxPost asder CFX 0 August 20, 2008 18:13
Make line on curved boundary in CFXPost? andy2O CFX 4 March 20, 2008 12:50
CFXPost & Cylindrical CS KG CFX 3 November 11, 2002 09:39
