Redhat Linux/CFX
Old   May 31, 2005, 19:17
Default Redhat Linux/CFX
Meri
I recently loaded cfx5.7 on a machine with redhat 9.0, I was suprised that it did not run. I checked the cfx website and it shows it should run under Redhat 9.0 Here is the error message I got, perhaps there is a way to fix it
CFX-5.7 (C) 1996-2004 CFX Ltd. All rights reserved./home/cfd5/cfx57/CFX-5.7/bin/linux/Launcher.exe: relocation error: /home/cfd5/cfx57/Shared/qt-3.2.3-1/lib/Linux/libqt-mt.so.3: symbol _res, version GLIBC_2.0 not defined in file libc.so.6 with link time reference An error has occurred in cfx5:
The CFX Launcher /home/cfd5/cfx57/CFX-5.7/bin/linux/Launcher.exe exited with return code 127.
Old   June 1, 2005, 05:43
Default Re: Redhat Linux/CFX
James Date
Try this.
In the CFX-5.7.1 installation manual page 22 it says that to use CFX-5.7.1 on Linux RedHat 9.0 platforms you need to install an RPM which patches the system to GLIBC version 2.3.2-27.9.4 or later. This RPM is available at http://rpmfind.net/linux/RPM/redhat/...-27.9.7.i686.h tml. You can check which version you have installed using the command: rpm -q glibc
A workaround while you are checking this is to use CFX-Pre with mesa (software) graphics rather than hardware graphics. You can do this by running CFX-Pre from the command line using cfxpre -gr mesa
James
[Netgen] Netgen segfaults tetmeshing on Redhat EL5 djvictoid OpenFOAM Meshing & Mesh Conversion 1 June 11, 2011 06:53
C++ manual for RedHat 9.0 Abhijit Tilak Main CFD Forum 12 September 16, 2004 03:44
CFX5.6 on Redhat 9 Jingo CFX 5 July 31, 2003 17:09
Setup on Redhat Linux 8.0 / OpenMotif Library Steve Lewis Siemens 3 April 3, 2003 10:20
Fluent on RedHat 8.0 Jonas Larsson FLUENT 4 November 8, 2002 22:30
