December 17, 2018, 22:33 |
Non-drag Forces
Pedro Oliveira
Rep Power: 8 |
How can I know if Lift, Turbulent Dispersion Force, Virtual Mass and Wall Lubrification Forces are important or not to my simulation?
Basically it consists in water and steam transient flow, with a continuous heat deposition, with Thermal Phase Change (Nusselt number=6) modelling the interphase mass and heat transfer., cooled by surrounding water cooling with 1.8Kg/s (30 cm size recipient - 1000W) |
December 17, 2018, 23:50 |
Rep Power: 143 |
The starting point for any question like this is always the CFX documentation.
Lift force: This is applicable in high-shear flows. CFX has 3 lift force models with difference applicability. The Legendre and Magnaudet model might be applicable to your case. Turb Dispersion force: This is applicable to model the random dispersion of particle due to turbulence. You should model this if this randomness is important. Virtual Mass: This is when the continuous phase is dense compared to the particle phase. It is not important for water droplets in air, but it is important for air bubbles in water. Wall Lube: Usually used with the wall lift force to model bubbles concentrating near, but not on, a wall. You should research these options, understand them, and make an informed decision about whether they are important in your case or not.
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
PimpleFoam - oscillating forces and drag coefficient | crizpi21 | OpenFOAM Running, Solving & CFD | 3 | July 2, 2018 11:53 |
Negative drag forces of fanwing airfoil | vkid185 | OpenFOAM Post-Processing | 0 | March 26, 2017 07:16 |
Writing drag forces of cylinders in fluent 14.5 | vishnum12 | FLUENT | 1 | December 23, 2015 06:19 |
How to write the drag forces and separate it into viscosity drag and pressure drag | Joanna Huang | OpenFOAM Post-Processing | 0 | January 7, 2013 11:37 |
