How can I specify mass flow rate as inlet bc and domain press. info. at same time? |
December 23, 2018, 20:11 |
Soumitra Vadnerkar
Rep Power: 7 |
There is a fluid flowing inside a tube and the pressure (3MPa) in the tube is given.
I have also given mass flow rate value at inlet. How can I define both of the properties in CFX-Pre? Should I put domain reference pressure as 3MPa (and 0 relative pressure as initial condition)? or should I put initial condition as 3MPa relative pressure and 0MPa as domain reference pressure? |
December 24, 2018, 01:56 |
Rep Power: 143 |
You cannot specify pressure and velocity at an inlet.
Some options include: * Specify the pressure at the inlet and the mass flow at the outlet * Specify the mass flow rate at the inlet and the pressure at an outlet. If the simulation is incompressible you can then simply offset the pressure field to a 3MPa inlet pressure. If the simulation is compressible you may need to try a few outlet pressures until the inlet pressure is correct.
domain boundary condition, initial conditions, pressure, reference pressure |
