Target Coarsening Rate for Discrete Transfer Radiation Model
Old   December 23, 2018, 16:02
Default Target Coarsening Rate for Discrete Transfer Radiation Model
canalpk
canalpk is on a distinguished road
Hello to all dear forum users,
My problem includes a gas filled annulus where inner hotter cylinder radiates to an outer cylinder. I am simulating this with surface to surface discrete transfer radiation model. The problem is I can't control the coarsening rate at Solver Control tab, it simply doesn't exist. And when I check the output file It is like this:
Target coarsening rate = 124560
Number of fine grid elements = 124560
Number of radiation elements = 1
Actual coarsening rate = 124560
This scares me since I am reading that default coarsening rate is 64 (or 16 I am not sure). And I am not sure if I am simulating the problem correctly.
I have read from an old post that for some situations this parameter cannot be specified, but at there these situations were not clarified.
It would be really helpful If someone can clarify the situation.
canalpk is offline   Reply With Quote
VoF Model, miscible fluids, mass transfer rate yulu Fluent Multiphase 0 May 12, 2017 07:48
Using radiation model for simulation of flat plate solar collector marjanbn FLUENT 1 February 24, 2017 17:22
Multiphase heat transfer pkladisios CFX 8 June 7, 2016 01:41
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
