July 18, 2005, 11:40 |
turbulent kinetic energy and dissipation
hai all,
i have doubt about turbulent kinetic energy and dissipation, ie generally how k and epsilon varies along radial and axial direction and i don't know where it is maximun and what is contidion at wall and center of wall actually k means how much energies in turbulence and epsilon means energy dissipating only due to viscous action , is't it?, i am confusing about k and epsilon please give some more explaination about k and epsilon, and also thanks with regards panneerselvam.R |
July 22, 2005, 01:55 |
Re: turbulent kinetic energy and dissipation
as you sad k is production and epsilon is dissipation of the turbulent kinetic energy. The way they are calculated depends on turbuletn model you are using. More information on the eqitations you can get in theory documentation. If you are engineer do not spend too much time with the equitation study just use the most appropriate turbulence model for your problem.
Turbulent kinetic energy and energy dissipation at boundary | mshotm2000 | FLOW-3D | 4 | December 12, 2016 09:44 |
turbulent kinetic energy and turbulent dissipation rate | D_L | Main CFD Forum | 5 | July 17, 2010 02:35 |
turbulent kinetic energy and this dissipation | hicham FATNASSI | Main CFD Forum | 0 | December 29, 2000 06:47 |
calculation of (turbulent) dissipation energy ? | max | Main CFD Forum | 3 | August 18, 1999 09:42 |
