August 12, 2005, 09:19 |
Compile subroutines
I just started to use user subroutine in CFX 5.7.1. For the time being, I tried to test to see how to compile the *.F files. I copied some sample fortran files to the working directory. But when I tried: ! system ("cfx5mkext PipeValve_inlet.F") == 0 or die; It respond : ERROR CCL parser failed with message: Perl Syntax errors detected: Died at (eval 15) line 2. I then tried to use OS command, cfx5mkext can not even be recognised by windows! It still did not work after I copied cfx5mkext.ccl to the working directory! I am using compaq vision fortran 6. Thanks for your help. Jamie |
August 20, 2005, 10:59 |
Re: Compile subroutines
Jamie,
Make sure you're running from a command window spawned from the CFX-5 launcher (under Tools | Command Window). This sets a large number of environment variables and paths necessary for cfx5mkext to work. Jeff |
August 22, 2005, 05:18 |
Thanks Jeff.
you are right! I did not know I should run the command window from CFX in the beginning. So I mannually modified the Path to include all the librairis and directories in CFX. It is working now. Cheers Jamie |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 | gwierink | OpenFOAM Installation | 0 | April 5, 2011 04:38 |
PV3FoamReader compile error.... | PEM_GUY | OpenFOAM Installation | 6 | April 5, 2010 17:22 |
Error compile file udf | czfluent | Fluent UDF and Scheme Programming | 24 | September 26, 2009 13:24 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
