time step
Old   August 30, 2005, 11:48
Default time step
Rob
Hi,there
For steady state problem, it usually need to give a large time step at beginning and then gradually reduce that.
How about the time step for transient problems? Should I give a large or small number to start the solver?
Can someone share your experience?
Regards!
Rob
Old   August 31, 2005, 18:11
Default Re: time step
Robin K
If the problem is stiff, then it is generally recommended that you start with a small time step, due to its instability issues at the start. But as the simulation progress, you could potentially increase the time step.
RK
Old   August 31, 2005, 20:08
Rob
Thanks Robin.
HELP! time step too small? meangreen Main CFD Forum 6 May 31, 2018 10:41
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
