March 20, 2019, 10:14 |
pump us turbine domain interface
addis abeba
hi their?
i'm working on pump as turbine, and I'm having trouble with pitch change. I am using frozen rotor for the frame change and when i use pitch angle automatic or none. it gives me a message that the option is invalid. Is there any body with idea or a solution? it is very much appreciated |
March 25, 2019, 02:25 |
M
Rep Power: 12 |
It is hard to follow what you are doing from your explanation.
Pitch change is used to describe a circumferential difference between two adjacent domains (stationary/rotating). You can find images and an explanation in the cfx user guide. If you change it to "None", CFX usually gives a warning message, not an error. If its just a warning and you really model 360° of the interface on both sides, you can ignore it. |
March 25, 2019, 03:58 |
urosgrivc
Rep Power: 11 |
why are you opening so many new posts
one is here below and I have seen another one somewhere pitch angle ratio Ok The answer to that one is , if this is the same problem you are talking about, is that you actually need 360°of the rotor so you can connect it to 360° of the stator and select pitch change to none. I think slide 9 and 12 are most relevant for you but check out all of the slides. https://slideplayer.com/slide/9398929/ look at stage interface https://www.sharcnet.ca/Software/Ans.../CACDIGEH.html This should work if you want to do it like you are triing to (only a part of rotor used in the sim) But I am not completly sure if this is apropriate, I would use a full 360 model Last edited by urosgrivc; March 25, 2019 at 07:55. |
Periodic Pressure drop | cfd_begin | CFX | 10 | May 25, 2017 07:09 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
