March 22, 2019, 06:57 |
CFX- negative heat flux ??
Rakshit
Rep Power: 8 |
Hi All,
It would be great if any one can give me some tips over defining the physics for my problem I have a enclosed cavity with a chiller unit in it. The initial temperature inside the cavity is 25 degC and external temperature out side the cavity is also 25 degC so with this condition I want to achieve a target temperature of 15 degC inside the cavity. Basically saying the chiller unit should suck the heat from inside the cavity and dissipate it to the out side (external environment ) so is it possible to define negative heatflux for the chiller unit ?? or is there any other way i can deal with this for reference I have attached a rough picture of my set up Many Thanks |
March 22, 2019, 18:01 |
Rep Power: 143 |
Yes, of course you can do that. You just define a negative heat source inside the cavity and positive heat source in the external environment.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 00:27 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Export Heat Flux CFX -> ANSYS Workbench | Freeman | CFX | 2 | April 11, 2010 08:24 |
Heat flux in ansys cfx | juliom | OpenFOAM Running, Solving & CFD | 2 | April 14, 2009 14:30 |
