Definition of boundary conditions and initial velocity for fluid domain
Old   March 24, 2019, 23:58
Question Block water hitting plate
dacdung
ddungntu is on a distinguished road
Dear all,
Thank you very much for your time and energy to give me your kind help.
I am trying to simulate the water block hitting a steel plate with velocity =4 m/s, using Ansys CFX (2-way FSI). I am interested in solution of pressure acting on steel plate and plate deformation.
To simulate this problem, I applied two-phase problem by introducing volume fraction of air and water. Then I applied the initial velocity=4 m/s to the water block, and 0 m/s for air domain. I defined all sides of fluid domain except for top of air domain as no slip wall, for the top of air domain defined as openning boundary with open pressure=0 Pa.
But unfortunately, the results of pressure and deformation obtained are small compared to what I expected.
I do not know what is wrong in my model.
Could you please correct me about boundary condition and initial conditions or other aspects to improve my solution?
Best regards,
Dac Dung
ddungntu is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
