Polyline in CFD-Post
Old   March 25, 2019, 13:11
Default Polyline in CFD-Post
HS
amsys is on a distinguished road
Hi All,
Does anyone know if it’s possible to create a Polyline on an imported user surface?
Thanks.
amsys is offline   Reply With Quote
Old   March 25, 2019, 17:00
Gert-Jan
Gert-Jan will become famous soon enough
Why not give it a try yourself?
Gert-Jan is offline   Reply With Quote
Old   March 26, 2019, 04:37
HS
I did and it didn’t work hence why I am asking if there is a way of doing so. Do you have a suggestion or were you curious of my skills set?
Old   March 26, 2019, 05:28
Gert-Jan
I am asking since you do not report a problem, but are asking a general question which suggests you didn't try it yourself first. Please be more specific next time.
To be honest, I don't know the answer since I never import a user surface. Can you create a polyline on the intersection of the user surface with a boundary or a plane? If not, it might be impossible. I suspect the results file uses nodes, and your user surface uses its own coordinates. They have nothing in common. But I might be wrong.
So, maybe you can explain what you want and then we can find out if there is a workaround within the framework of CFD-Post.
Old   March 26, 2019, 06:10
HS
Apologies for the vagueness.
I am trying to extract a variable circumferentially on the wall of an artery model every 1mm across the length of my model. I have already created a matlab/ANSYS interface code that will do this for Wall Shear (which is simple since this variable is a solution variable from the simulation) automatically.
For my calculated variable this is where I’ve gotten:
I exported a csv. file with Wall shear variable and the connecting, face, node info and calculated my new variable via matlab (unfortunately couldn’t calculate this variable in Post). I replaced the Wall Shear column with my new variable in the csv. file and imported this as a user surface back into CFD-Post.
I created a plane with the option point and Normal, the plane bound being circular and the bound radius being that of the arterial diameter.
I then create a polyline where it asks for the boundary list which I select as my wall domain as it won’t allow me to select anything relating to my user surface! I select the location as my plane.
I then go to export where I select location as polyline and the variable as the variable on my user surface. However, I get an error that this variable isn’t part of the geometry....
I am pretty stumped but hoping there will be a workaround however tedious to overcome this!
Old   March 26, 2019, 07:53
urosgrivc
urosgrivc is on a distinguished road
why weren't you able to calculate your variable in post?
There is a tab called variables in the post, You can write your own.
there is also a tab called User surface so you can import your own too.
I probably don't understand exactly what you want but, I am sure something can be done as all the
tools you are talking about are there.
urosgrivc is offline   Reply With Quote
cfd-post, user surface
Post processing in CFD Post or Fluent. Blobs OpenFOAM Post-Processing 2 June 26, 2016 07:23
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
calculating output parameter in cfd post markus67 CFX 3 August 26, 2015 09:28
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan Visualization & Post-Processing 0 April 23, 2015 16:07
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 00:30
