March 26, 2019, 23:41 |
Creating heat loss in a cell zone
Aja
Rep Power: 14 |
I want to apply heat loss in a zone from my model (For example, -140000 w/m3). So, I created a subdomain in the mentioned zone and according to the following picture, I enabled "sources" option. Then, in energy equation, I applied the mentioned heat loss. Now I have a question: For applying this heat loss, Am I right? Is this method correct for creating the heat loss? I am grateful that guide me in this case. Thanks. |
March 27, 2019, 05:45 |
Rep Power: 143 |
Yes, that looks correct.
But you really should check this yourself. Do a simulation and run to convergence. Then get the flow into your domain and get the enthalpy (or some measure of heat energy), and compare it to the exitting enthalpy. The difference in enthalpy should be the power applied in your source. This is a check the source is doing what you expect.
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Evaporation-Condensation in a porous zone (Heat transfer problem) | maximilian-1 | Fluent Multiphase | 1 | August 22, 2018 09:42 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
Change cell zone index/thread during simulation | neilduffy1024 | FLUENT | 0 | January 17, 2011 09:40 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
