March 28, 2019, 08:58 |
Material Properties by expressions
Hey folks,
i want to simulate the flow of liquid oxygen. In a preliminary simulation i used a constant property liquid and everything worked fine. Now i want to account for changes in fluid properties. I defined expressions for the density, heat capacity, dynamic viscosity and the thermal conductivity as functions of p and T (pressure and Temperature). I checked the units and the values and they are correct. If i don't setup a table CFX-Pre starts complaining. I tried to start a simulation with and without a table but either way the solver stops immediately. Is there a major mistake in my setup? Do i need a table? I heard about problems when defining density and the heat capacity at the same time but i couldn't find any related threads. Thanks in advance |
March 28, 2019, 09:27 |
Rep Power: 32 |
The CFX-Solver nearly always creates a table from the fundamentals properties given by expressions.
For example, how would compute Enthalpy from a Cp expression? How would you compute Entropy from expressions for density and Cp? Thermodynamic properties are not independent, they MUST satisfy the Maxwell relationships; otherwise, the energy balance equations will not work properly. See ANSYS CFX documentation for a light description of the minimum requirements. |
error, expressions, material, properties |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
[Other] Material properties in multi region foam and refining mesh for each region | mukut | OpenFOAM Meshing & Mesh Conversion | 2 | October 7, 2013 02:08 |
Material Properties in COMSOL for different domains with different physics | TryMyBest | COMSOL | 0 | March 5, 2013 08:23 |
Material Properties table? (function of two variables) | evcelica | CFX | 2 | October 1, 2012 19:36 |
Vaiable Material properties | Pialisen | FLUENT | 2 | November 29, 2006 13:12 |
