Material Properties by expressions
Old   March 28, 2019, 08:58
Default Material Properties by expressions
testaccount is on a distinguished road
Hey folks,
i want to simulate the flow of liquid oxygen. In a preliminary simulation i used a constant property liquid and everything worked fine.
Now i want to account for changes in fluid properties. I defined expressions for the density, heat capacity, dynamic viscosity and the thermal conductivity as functions of p and T (pressure and Temperature). I checked the units and the values and they are correct. If i don't setup a table CFX-Pre starts complaining. I tried to start a simulation with and without a table but either way the solver stops immediately.
Is there a major mistake in my setup?
Do i need a table?
I heard about problems when defining density and the heat capacity at the same time but i couldn't find any related threads.
Thanks in advance
testaccount is offline   Reply With Quote
Old   March 28, 2019, 09:27
Opaque will become famous soon enough
The CFX-Solver nearly always creates a table from the fundamentals properties given by expressions.
For example, how would compute Enthalpy from a Cp expression? How would you compute Entropy from expressions for density and Cp?
Thermodynamic properties are not independent, they MUST satisfy the Maxwell relationships; otherwise, the energy balance equations will not work properly.
See ANSYS CFX documentation for a light description of the minimum requirements.
Opaque is offline   Reply With Quote
error, expressions, material, properties
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
[Other] Material properties in multi region foam and refining mesh for each region mukut OpenFOAM Meshing & Mesh Conversion 2 October 7, 2013 02:08
Material Properties in COMSOL for different domains with different physics TryMyBest COMSOL 0 March 5, 2013 08:23
Material Properties table? (function of two variables) evcelica CFX 2 October 1, 2012 19:36
Vaiable Material properties Pialisen FLUENT 2 November 29, 2006 13:12
