April 12, 2019, 07:45 |
Mass transfer
jalal kheadr
Rep Power: 7 |
Hello
my project is: The bubble column modeled in the simulation is semi-batch where air flows continuously through a batch layer of water-oil The distributor inlet at the bottom of the vessel has only air flowing through it (air volume fraction =1). ,is the mass transfer really needed to completely simulate the flotation of oil? if it needed,any model of mass transfer must i used, i mean Specified Mass Transfer or phase change or Cavitation? Second question: in fluid pair models just the two pairs air-water kerosene-water appears in the tab, why the pair (air-kerosene) does not appear? Thank you for help. |
April 12, 2019, 10:02 |
Gert-Jan
Rep Power: 27 |
Why do you do CFD? What do you want to predict?
In other words: which question are you trying to answer with your CFD-calculations? |
April 12, 2019, 10:07 |
jalal kheadr
Rep Power: 7 |
I want to simulation the flotation process (flotation of emulsion), three phase process (air-kerosene-water), as I mentioned in my question, is the mass transfer really needed to completely simulate the flotation of oil?
April 12, 2019, 10:52 |
Gert-Jan
Rep Power: 27 |
That did not answer my question. As an example:
- If I simulate a car, I want to know the Cw. - If I simulatie a pump, I would like to know if it cavitates at a certain operation point, or the efficiency at a certain rpm. - If I simulate a DAF-process (Dissolved Air Flotation), I want to know if the air bubbles distributie homogeneously over the incoming water, if they all leave the water with the emulsified solids at the top and do not end up in the clear water stream (carry-over). So: what question are you trying to answer using CFD? And what mass-transfer do you think you need? From where to where? Do you have dissolved air and want to include the mass transfer to air bubbles? Or something else? Please be as specific as you can be. Don't let us guess. Regs, Gert-Jan |
April 12, 2019, 10:59 |
#5 | |
jalal kheadr
Rep Power: 7 |
April 12, 2019, 11:18 |
Gert-Jan
Rep Power: 27 |
It depends on how you setup your model and what question you are trying to answer. Do you work with Population Balances? Then there is mass transfer between the populations. But maybe you don't need it and are not interested in this. I don't know.
Also there is mass transfer from air in dissolved state to gas state. But, that is very difficult to model. Try to avoid that. But maybe you have to include it. I don't know. I can't give advice if you don't want to tell what question you are trying to answer. Please be specific (last time). Did you read this post: Before you post a question please read this |
April 12, 2019, 11:30 |
#7 | |
jalal kheadr
Rep Power: 7 |
please contact to me, in order to send the detail of the project |
mass transfer coefficient | ArturTU | FLUENT | 1 | October 27, 2015 10:04 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
About phase change heat and mass transfer | Michael | FLUENT | 2 | February 13, 2011 01:49 |
How to calculate Volumetric Mass transfer coefficient using CFX? | tuks_123 | CFX | 2 | July 22, 2010 01:15 |
Vof, udf and mass transfer panel | Jay | FLUENT | 1 | March 15, 2005 00:29 |
