May 3, 2019, 00:02 |
turbine force_y vs dP * area
Svetlana Tkachenko
Rep Power: 14 |
In ansys 19.2 the built in function
force_y()@turbine Default and a similar manual calculation (here 'top' and 'bottom' are circular surfaces below and above the turbine) (areaAve(Pressure)@bottom - areaAve(Pressure)@top ) * area()@top give different results 2-3 times, inconsistently in different cases as it is not a linear relationship. Is this a known issue? How do I troubleshoot this? Can attach a small test case if anyone is interested. |
May 3, 2019, 02:26 |
Rep Power: 143 |
your areaAve functions just average the pressure over the surface, they do not take into account direction. The force_y function only gets the force in the y direction. So your function is not working out the force in the y direction.
May 3, 2019, 02:31 |
Svetlana Tkachenko
Rep Power: 14 |
In this case my calculations should give larger values than CFX's force_y,
because they do not multiply by cos (direction angle) in each point. However in my case the "dP * area" calculation gives results which are 0.3 to 0.7 of the force_y value predicted by CFX. |
May 3, 2019, 02:34 |
Rep Power: 143 |
If you want us to help you, you are going to have to post an image of what you are analysing, a description of what the top and bottom surfaces are and a plot of the pressure distribution.
lift and drag, post procesing, propeller, turbine |
[ANSYS Meshing] How to properly mesh whole wind turbine (structured mesh on curved geometries) | rusham | ANSYS Meshing & Geometry | 3 | February 16, 2020 14:29 |
Modelling a rotating Savonius turbine | BleuBleu | ANSYS | 3 | March 5, 2019 07:01 |
fluen reference values for blade area and length | nouman95 | FLUENT | 7 | January 25, 2019 10:19 |
Turbine analysis of the turbocharger | YOUNS | CFX | 1 | September 21, 2018 06:36 |
Analysis of Tesla turbine | shahryar | FLUENT | 5 | February 1, 2018 08:33 |
