June 7, 2019, 10:21 |
CFX Run Crashes when using lots of CPU cores
Hello, I have been running into an issue where CFX will crash with this error when running with more than 5 cores.
+--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Cannot write contents of handled_errors.txt to output file: | | Permission denied | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. I am adjusting the contact resistance in my simulation and as it becomes very close to zero, I can only use 2 cores. What would be causing this? |
June 8, 2019, 06:48 |
Rep Power: 143 |
I don't know. How many physical cores does your workstation have? Is it running any other software at the time? Virus checkers are notorious for causing this sort of grief. Try running it with the virus checker turned off.
ansys, cfx, cores, crash, error |
Best cost-effective 2 CPU Hardware 2017-2018 for ANSYS CFX R17 | Noco | CFX | 6 | January 16, 2018 00:37 |
how to increase cores number when we use CFX and ansys solvers | WANGFIRE | CFX | 2 | September 30, 2015 08:56 |
Why cores number in CFD simulation is preferred to be integer multiple of 4 for CFX? | Pierre1 | CFX | 4 | March 23, 2015 19:20 |
OpenFOAM 13 Intel quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 13 | February 5, 2008 05:26 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 10, 2007 23:23 |
