User Surface, Calculator
Old   November 14, 2005, 09:33
Default User Surface, Calculator
Christian Bruzzese
I have tried to use the CFX POST Calculator to evaluate the flow field through a User Surface in CFX Post.
But the results have no sense. It seems that there are only four mesh points on the User Surface: the four end points of the rectangle
that defines the User Surface. The mesh points lying in the inner part are not considered, unlike when using a PLANE.
The problem is that I have to use a USER Surface in order to evaluate the flow field over a bounded area which lies completely in the flow field.
Does somebody know more about using a the Calculator on a User Surface?
Thanks
Christian
Old   November 14, 2005, 18:00
Default Re: User Surface, Calculator
Rui
How have you created the User Surface?When you visualize it with the "Draw Lines" option (Render tab) enabled, do you see the lines?
Rui
Old   November 15, 2005, 02:37
Christian Bruzzese
HI, I created the User Surface with the option: FROM FILE and then referenced to a text file which contains the coordinates of the 4 end points of the user surface (it's explained in the help of cfx).
NO, I can't see the projection of the mesh elements on the user surface.
Old   November 15, 2005, 10:13
Rui
Hi Christian,
I've never created user surfaces through that method. But it seems you have to include the inner points in the text file.
Rui
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface James Date CFX 3 August 10, 2012 04:47
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
