Reduced pressure rise in numerical simulation |
July 9, 2019, 12:14 |
Rep Power: 14 |
I am modelling a 1.5 compressor stage.
I have experimental data at inlet to bell-mouth, IGV, Rotor and Stator. I am using mass flow and total temperature at inlet and static pressure at outlet boundary conditions. However, the numerical model does not rise static pressure and total pressure as the experimental data. The difference is minimal but I do not understand why this happens. I have checked the dimensions, boundary conditions and blade angles and everything seems right. Is there a way to check this problem? |
July 9, 2019, 19:23 |
Rep Power: 143 |
Yes, this FAQ describes the process: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
And the link in this FAQ is an excellent guide as well: https://www.cfd-online.com/Wiki/Ansy...publishable.3F
Post-processing Pressure in a boiling simulation | soumitra2102 | CFX | 3 | December 26, 2018 03:45 |
Simulation of ball-valve opening w.r.t to varying inlet pressure | wasim_03 | Main CFD Forum | 1 | January 6, 2018 12:40 |
CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 06:50 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
Low pressure de Laval simulation convergence problem | heksel8i | FLUENT | 3 | July 22, 2013 10:28 |
