Is possile to load transient files automatically ?
Old   December 23, 2005, 09:37
Default Is possile to load transient files automatically ?
veera
Hi Everybody, I have transient results for 300 time steps. And I want to take results for each substep (Example: pressure at outlet for each time step). It is very difficult to load each file and take result.
So Is there any process to take the results automatically without loading files manually, As we take animation by loading the first and last time step.
Thanks Satish
Old   December 25, 2005, 02:57
Default Re: Is possile to load transient files automatical
TB
If you are looking for quantitative result, write a loop using PERL language in command window and save result as text file. Refer to Post user manual for details.
Old   December 26, 2005, 01:58
veera
Hi TB,
Thanks, I will try that.
Satish
Old   December 26, 2005, 09:13
veera
Thanks TB,
I got it. But the results are getting printed in CFX window. I am copying from there at the end. Is there any possibility to save directly in stecifird file.
Thanks Satish
Old   December 26, 2005, 14:25
TB
I'm not sure what variable you're trying to export but I normally use two different approaches to output the results: 1. Use command "print" to save the results in a text file 2. Use CFX supplied function: EXPORT (see user manual for details)
Old   December 31, 2005, 03:31
Joe
Yes you can use perl-commands to write out values to a ASCII file. Use for instance:
!open (FIL, ">ascii.dat") or die $!;
!print FIL $value." \n";
!close(FIL);
Regards Joe
Old   January 2, 2006, 01:40
veera
Thanks TB and Joe.
My problem got solved with your help.
Regards veera
Create Case Files automatically? Christoph_84 OpenFOAM 1 September 23, 2010 09:27
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Importing .sfe load files from CFX to Ansys ADPL Eyezac ANSYS 0 May 14, 2010 18:09
Load written xy plot then FLUENT close automatically khimkhim FLUENT 0 March 15, 2010 23:49
200 data files to post process (how?) Mark R FLUENT 1 August 9, 2001 13:35
