September 10, 2019, 17:11 |
Changing differential equation in CFX
Sai Abhishek Siddhartha
Rep Power: 6 |
Is there a way to change the terms of Differential equation(Especially momentum equation)?
I was hoping that i could 1) Input the values of Coriolis force and Centrifugal force, so as to examine their effect on my system 2) Turnoff the Coriolis force component, and only have centrifugal force Please help |
September 10, 2019, 18:17 |
Rep Power: 32 |
May I ask why would you want to do that? The equations would be incorrect; therefore, any conclusions will be polluted.
Perhaps you want to compare the contributions to the momentum equation, i.e. a force balance. You can compute the sources yourself via expressions, and compare the ratio between them. Say Coriolis force/pressure force, Coriolis force/inertial term or the like In fact, you may want to read about the following dimensionless number associated with rotating physics Rossby/Kibel number Taylor number Ekman number |
September 11, 2019, 01:18 |
#3 | |
Rep Power: 6 |
Thanks! |
September 11, 2019, 06:06 |
Rep Power: 143 |
You can add the centripetal and coriolis effects as a momentum source terms. That what you can turn them on and off, or double one and halve the other or whatever you like. Have a look in the documentation on the source terms used for the rotating domain model and write your own source terms for them.
Note that compressible flow has additional changes in rotating frames of reference which might be a little harder to reproduce - again, see the CFX documentation for details.
September 12, 2019, 08:37 |
#5 | |
Rep Power: 6 |
I have searched the documentation thoroughly, where I couldn't explicitly any reference to control Coriolis and centrifugal source terms. Additionally I have to solve the problem/equation in stationary domain. Could you kindly provide some reference in documentation/tutorials where these changes can be done? Thanks a lot! |
September 12, 2019, 18:46 |
Rep Power: 143 |
You can't control the Coriolis and Centripetal terms. You can only turn them both on and off by activating the rotating frames of reference model.
My post said if you want to control them individually you need to define a momentum source term using the same equations as used in the rotating frame of reference model. As you define this source term, you can define the inputs any way you like.
September 15, 2019, 06:26 |
Rep Power: 6 |
Thanks for your reply.
How do I change/deactivate the rotating frames of reference model? Also can you please guide me regarding where can I add momentum source terms in CFX? Is it part of buoyancy acceleration in boundary conditions or should I use some programming language? Thanks a lot! |
September 15, 2019, 18:59 |
Rep Power: 143 |
Please do the CFX tutorials and read the documentation. All your questions are very basic questions which are explained well in the documentation. The search function works well and you will find details of the source terms soon enough.
centrifugal force, cfx solver control, coriolis force, differential equations |
CFX Electric Potential Equation Residual Problem | hsezsz | CFX | 2 | October 7, 2016 03:35 |
Explicit Runge-Kutta of a Differential Equation | HakikiCanakkaleli | OpenFOAM Programming & Development | 1 | September 25, 2014 06:18 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Basic question about writing a differential equation related to finite element | RbBb | Main CFD Forum | 1 | April 10, 2014 03:50 |
CFX Additional Variable Transport Equation | Scott Nordsen | CFX | 3 | January 30, 2010 05:36 |
