courant number
Old   February 4, 2006, 10:21
Default courant number
cfd worker
What is courant number ?.what is the significance of courant number?Is it related to time step?
Old   February 8, 2006, 20:15
Default Re: courant number
Robin
The courant number is the ratio of the timestep to the characteristic time of a control volume (i.e. the time required for fluid to travel through the control volume). Explicit solvers require that the maximum courant number is always less than 1 in order to remain numerically stable. CFX uses an implicit solver, so second order accuracy for transients can be acheived for courant numbers much larger than 1. With an implicit solver, the timestep is determined by the physics, not the numerics.
That said, for some applications it is necessary to keep the courant number low, but it is not strictly required for all transient runs.
Regards, Robin
Courant number fireman FLUENT 7 September 11, 2021 11:33
IcoFoam unstability, courant number gets large! vivien OpenFOAM 11 March 9, 2017 03:45
LES near wall model & courant number kasim CFX 5 March 16, 2008 18:23
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Courant number calculation - unsteady flow Kuba FLUENT 0 November 8, 2005 22:44
