Thermal Two Fluid (Not Interacting with Each Other) in CFX |
December 13, 2017, 10:01 |
Abid Khan
Rep Power: 8 |
Consider the case portrayed in the image, is it possible to analyse (thermal analysis) two fluid (nitrogen and air) which are not interacting with each other (not in direct contact with each other) in CFX? I'm having trouble in assigning material to the fluid domains. When I assign material air to the domain air, it automatically changed the material of domain nitrogen to material air. When I correct it by changing the material to nitrogen, it changes the material of domain air to material oxygen. It look like these two fluids are interconnected and changing material of one domain updates the material of other fluid domain by itself. I doubt that only one independent fluid can be analyzed in CFX. Is it true? |
December 13, 2017, 15:14 |
Rep Power: 32 |
ANSYS CFX definitely can model two disconnected fluid domains, but it is not a mainstream setup.
You must enable beta features. For an existing case, open the Case Options , Enable Beta Features, Disable Constant Domain Physics. At this point, you must be careful since the software may not be completely stable (beta mode). Alternatively, you can set up the case with the same material, different fluid name until most of the setup is done, then enable beta features and try it. |
December 13, 2017, 16:38 |
Rep Power: 143 |
The officially supported method to do this is to use a multicomponent mixture and define the mass fractions to make one region air and the other nitrogen. multicomponent mixtures are not very CPU intensive so this might be a practical option for you.
An alternate approach is to use the beta feature option described by Opaque, but as he says, it is a beta feature so you use it at your own risk. |
December 13, 2017, 20:35 |
Abid Khan
Rep Power: 8 |
I'll try this today.
December 13, 2017, 20:37 |
#5 | |
Abid Khan
Rep Power: 8 |
I'll try this method today. |
December 13, 2017, 20:41 |
#6 | |
Abid Khan
Rep Power: 8 |
December 14, 2017, 00:17 |
Rep Power: 143 |
The SS (which I assume is stainless steel) which separates the two gasses is a solid domain and can be given the properties of stainless steel. This is a conjugate heat transfer (CHT) simulation between the two fluid domains and the solid domain between them.
December 14, 2017, 08:25 |
Abid Khan
Rep Power: 8 |
Thank you very much for you reply. I'll google for tutorial on conjugate heat transfer using multicomponent method. And yes, SS is stainless steel.
December 14, 2017, 15:29 |
#9 |
Rep Power: 32 |
If you follow Glenn's suggestion of using multicomponent approach (which is limited and you will find out later if you need additional functionality) be certain you set the material components as algebraic; therefore, no need to solve any equations nor boundary conditions.
You must initialize these expressions to be 1 in the domain the material exists, and 0 in the other. Similarly for the second material component. How do you do it? COMPONENT: Material 1 Mass Fraction = inside()@Domain 1 COMPONENT: Material 2 Mass Fraction = inside()@Domain 2 Done!! |
December 15, 2017, 00:15 |
#10 | |
Abid Khan
Rep Power: 8 |
December 15, 2017, 00:20 |
#11 |
Abid Khan
Rep Power: 8 |
I've tried to learn the multicomponents but this method seems to be for mixtures (two fluids interacting with each other) whereas in my case there is no such case of mixing. I'm unable to understand to procedure. If you can spare some time, can you setup the above case (with coarse mesh) and send it to me for my understanding so that I can apply the same methodology in my case.
December 15, 2017, 00:39 |
#12 |
Rep Power: 143 |
The risks of beta software is that the software provider (ie ANSYS) does not guarantee the stability, robustness and accuracy of the results. It is not fully tested, and might have physics options which are not compatible with it. So weird things might happen. Also it is not included in the documentation so you don't know much background about it.
So in short: You use beta features at your own risk, and you have to keep an eye out for strange behaviour and incorrect results. If you don't have enough experience to be able to identify strange behaviour and incorrect results then you probably should not be using beta features. Yes, the multicomponent mixture model was designed to model two gas species which are mixed. But it can be used in your situation by simply setting the mass fractions to pure one species in one domain and pure the other species in the other domain (opaque's suggestion is an example of how to do this). So even though you have to define diffusivities and related mixing parameters, if the species aren't mixing then they don't come into it. So you can define anything you like for diffusivity. Sorry, I do not have time to set up a case for you. Have a look at the CFX tutorial examples which use multicomponent mixtures for examples on how to set this up. Make sure you do not get confused with multiphase flows - multiphase is completely different. You are looking for multicomponent mixtures. |
December 15, 2017, 06:25 |
#13 | |
Abid Khan
Rep Power: 8 |
February 13, 2018, 00:11 |
#14 | |
Abid Khan
Rep Power: 8 |
While setting up the domain (Air), in "Fluid Models" tab and under "Component Model" Field, I've two components of the mixture i.e. Air and Nitrogen. I clicked on the Air and selected "Algebraic Equation" from the options drop down list. Now here I'm bit confused about entering the Mass Fraction. Kindly guide me how to enter it algebraically for my two mixtures (air and nitrogen) for the domain "AIR"? |
February 14, 2018, 01:02 |
#15 |
Abid Khan
Rep Power: 8 |
I've used inside()@Air and inside()@Nitrogen where Air and Nitrogen are domain names. I get following error message: Code:
Details of error:- ---------------- Error detected by routine PEEKI CDANAM = NWORK CRESLT = NONE Current Directory : /FLOW/PHYSICS/MATERIALS/MT2/DENSITY +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine DELDAT CDANAM = KE CRESLT = NONE Current Directory : /FLOW/SOLUTION/TSTEP0/CLOOP0/ZN1/VERTICES I'm stuck, please help. |
February 14, 2018, 16:50 |
#16 |
Rep Power: 143 |
I would not call a domain "Air" or "Nitrogen" as it may get confused with the material names. Give the domains names which are definitely unique.
February 14, 2018, 21:04 |
#17 |
Abid Khan
Rep Power: 8 |
Yes, I tried by renaming the domains too air1 and nitrogen1 but error remains the same.
February 14, 2018, 21:19 |
#18 |
Rep Power: 143 |
It is hard to understand CFX error messages, they are very cryptic. But I suspect the error message you quote is saying that density is not defined for one of your materials. So check you have defined the density, or if you are using an equation of state that all the inputs to the EOS are defined.
February 19, 2018, 03:10 |
#19 |
Abid Khan
Rep Power: 8 |
Dear Glenn,
I've fully defined the materials and even tried using the materials present in the CFX library just to check if anything wrong with the properties. I still got the same error. Please see below the detailed error code which is saying something that pressure is not set at any boundary condition in Nitrogen1 domain. However, I'm defining the pressure as 1atm in both air and nitrogen domains in buoyancy setting. May be you understand something from this log: Code:
+--------------------------------------------------------------------+ | Buoyancy Reference Information | +--------------------------------------------------------------------+ Domain Group: Air1 Buoyancy has been activated. The absolute pressure will include hydrostatic pressure contribution, using the following reference coordinates: ( 5.39090E-01, 2.37276E+00, 5.39090E-01). Domain Group: Nitrogen1 Pressure has not been set at any boundary conditions. The pressure will be set to 0.00000E+00 at the following location: Domain : Nitrogen1 Node : 1 (equation 1) Coordinates : ( 5.28000E-01, 3.51700E+00, 3.19000E-01). Domain Group: Nitrogen1 Buoyancy has been activated. The absolute pressure will include hydrostatic pressure contribution, using the following reference coordinates: ( 5.28000E-01, 3.51700E+00, 3.19000E-01). Details of error:- ---------------- Error detected by routine PEEKI CDANAM = NWORK CRESLT = NONE Current Directory : /FLOW/PHYSICS/MATERIALS/MT2/DENSITY +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine DELDAT CDANAM = KE CRESLT = NONE Current Directory : /FLOW/SOLUTION/TSTEP0/CLOOP0/ZN1/VERTICES +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. |
February 19, 2018, 04:57 |
#20 |
Rep Power: 143 |
The line "Pressure has not been set at any boundary conditions. The pressure will be set to 0.00000E+00 at the following location" is ominous.
It appears you have not set the pressure, so the solver has set a point to zero pressure. If you have not set a reference pressure properly this will result in zero and possibly negative absolute pressures and this will destroy most EOS equations and give you a density error. Check that your initial and/or boundary conditions are set correctly, such that the pressure is properly defined.
multiple fluids, thermal |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 05:57 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 15:34 |
