Naca airfoil with to much drag
Old   March 15, 2006, 10:26
Default Naca airfoil with to much drag
Andreas
Hi!
I try to calculate a flow around some Naca 4 digit airfoils. In my calculation the lift is nearly right, but the drag is much too high. I'm comparing the calculated values with the book "theory of wing sections". Can you give me a reason or advice? I use a wall as boundary condition for a profil and the calculations are done with the standard k-epsilon turbulence model.
Thank you Andreas
Old   March 15, 2006, 10:41
Default Re: Naca airfoil with to much drag
ms
The K-E is probably your problem. they are not ideally suited for these kind of flows. An SST model would prob give you better results.
Old   March 15, 2006, 10:53
Andreas
Hi!
I tried this too, because I had the same idea but the results are nearly equal. So I don't know what I'm doing wrong.
Andreas
Old   March 15, 2006, 12:22
Ogbeni
What advection scheme are you using ? Try specified Blend or High Res.
Old   March 15, 2006, 12:43
vijesh joshi
what scheme you are using? because if you are trying for some supersonic / hypersonic case, then use upwind scheme. other thing is use local time scale factor<1.
Old   March 15, 2006, 12:52
PetrK
Check this forum, there are a lot of topics with this problem. You need very fine mesh, y+ bellow 2, run as transident, SST turbulence model with transition model, high resolution advection scheme.
Old   March 17, 2006, 06:13
AndiMb
Hi!
Thanks for your help. It worked. Sorry, that I didn't search in the post.
Andreas
Lift and Drag Coefficient data for NACA 2412 Airfoil mahbub03 Main CFD Forum 22 May 25, 2014 15:39
Lift and drag coefficient with strange values for NACA airfoil antonio_ing OpenFOAM Running, Solving & CFD 16 September 13, 2012 12:21
Symmetric NACA Airfoil Lift and Drag Data jrider22 Main CFD Forum 3 April 15, 2010 04:59
NACA 23020 airfoil drag and lift calculation. Zmur CFX 2 December 23, 2008 16:35
Drag prediction for Naca 23012 airfoil Ravel Bogatec CFX 17 February 15, 2008 00:21
