user defined function
Old   April 29, 2006, 10:58
Default user defined function
cfduser
hi all,
i am getting error while user defined routine for inter phase drag model between two phases
the problem is solver is running but it showing details of errors with number of times for every iterations
+--------------------------------------------------------------------+ | Convergence History | +--------------------------------------------------------------------+
================================================== ==================== | Timescale Information | ---------------------------------------------------------------------- | Equation | Type | Timescale | +----------------------+------------------------+--------------------+ | U-Mom-Water | Auto Timescale | 1.70168E-01 | | V-Mom-Water | Auto Timescale | 1.70168E-01 | | W-Mom-Water | Auto Timescale | 1.70168E-01 | | U-Mom-mysolid | Auto Timescale | 1.70168E-01 | | V-Mom-mysolid | Auto Timescale | 1.70168E-01 | | W-Mom-mysolid | Auto Timescale | 1.70168E-01 | +----------------------+------------------------+--------------------+ | Mass-Water | Auto Timescale | 1.70168E-01 | +----------------------+------------------------+--------------------+ | Mass-mysolid | Auto Timescale | 1.70168E-01 | +----------------------+------------------------+--------------------+ | K-TurbKE-Water | Auto Timescale | 1.70168E-01 | +----------------------+------------------------+--------------------+ | E-Diss.K-Water | Auto Timescale | 1.70168E-01 | +----------------------+------------------------+--------------------+
================================================== ==================== OUTER LOOP ITERATION = 1 CPU SECONDS = 3.34E+00 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+
Details of error:- ---------------- Error detected by routine PEEKCS CDANAM = /USER/USER_PRINTING CRESLT = NONE USER_PEEKCS failed for CFluidC with CRESLT = NONE USER_PEEKCS failed for CFluidD with CRESLT = NONE USER_PEEKI failed for MaxDPhases with CRESLT = NONE
Details of error:- ---------------- Error detected by routine PEEKCS CDANAM = /USER/USER_PRINTING CRESLT = NONE USER_PEEKCS failed for CFluidC with CRESLT = NONE USER_PEEKCS failed for CFluidD with CRESLT = NONE USER_PEEKI failed for MaxDPhases with CRESLT = NONE | U-Mom-Water | 0.00 | 1.9E-03 | 9.2E-03 | 9.0E-02 OK| | V-Mom-Water | 0.00 | 1.9E-03 | 9.9E-03 | 8.8E-02 OK| | W-Mom-Water | 0.00 | 4.3E-04 | 7.6E-03 | 2.9E-01 ok| | U-Mom-mysolid | 0.00 | 2.8E-05 | 3.6E-04 | 3.4E-01 ok| | V-Mom-mysolid | 0.00 | 2.7E-05 | 3.1E-04 | 3.1E-01 ok| | W-Mom-mysolid | 0.00 | 4.3E-01 | 1.1E+00 | 1.9E-05 OK| | P-Vol | 0.00 | 1.0E-06 | 1.3E-05 | 17.7 4.2E-02 OK| +----------------------+------+---------+---------+------------------+ | Mass-Water | 0.00 | 1.1E-01 | 8.2E-01 | 5.8 3.3E-08 OK| | Mass-mysolid | 0.00 | 1.0E+00 | 6.2E+01 | 6.1 6.3E-07 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE-Water | 0.00 | 2.9E-01 | 2.5E+00 | 5.6 1.2E-07 OK| | E-Diss.K-Water | 0.00 | 2.3E-01 | 1.6E+00 | 7.1 9.3E-08 OK| +----------------------+------+---------+---------+------------------+
================================================== ==================== OUTER LOOP ITERATION = 2 CPU SECONDS = 1.84E+01 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 08:53
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
User defined function - CO level hari FLUENT 0 October 24, 2007 00:11
Help: user defined function alice FLUENT 3 December 13, 2000 00:10
