time step??????????
Old   May 6, 2006, 02:47
Default time step??????????
vijesh joshi
hi friends. What is this time step? and why it is required? what is its role in a steady state problem? these are my questions in this message. Please find the answers and help me out. thank you.
Old   May 6, 2006, 06:17
Default Re: time step??????????
Rui
Answer: [b]D o c u m e n t a t i o n[b]
Old   May 6, 2006, 19:26
Doug
Hello Vijesh,
What is the difference between a mouse ?
D.
Old   May 8, 2006, 05:18
Ihab Sraj
It has to do with accelerating the solution for steady state problems. U can just ignore it by setting it to autoscale time step......
Old   May 8, 2006, 15:28
Ben Akih
hi vijesh, i also had the same problems like you are having with the physical time step. i think this has to do with adavancing the solution within the compuational domain. cfx advises you to take one quarter or half of the typical residence time of the flow in your domain. simply put: for a quasi- 1D problem with vel. u traversing a domain with length scale l, the residence time is then approximated t as l/u, and the physical timestep is betwen 0.25*t and 0.5*t. best way to get round it is to try out different values. the convergence of your solution may depend on that. hope this helps. ben.
Old   May 9, 2006, 10:17
vijesh joshi
Hi Ben and Ihab. Thanks for replying. Please be in touch. We can learn together. From your pleasant response, I feel our thinking styles match with each other. Regards VVJ.
HELP! time step too small? meangreen Main CFD Forum 6 May 31, 2018 10:41
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
