Count Particle at Region
Old   April 3, 2020, 05:27
Default Count Particle at Region
IrieConqueror is on a distinguished road
hey,
i do euler lagrange simulation. i have different particle diameter. after, lets say 50s (stop criterion), i want to know how many particles of all specific diameters reached a wall.
i know i can set every diameter individually in PRE, do the simulation and the out-file shows me how many reached the wall.
but i want to examine alot of different diameters, so i would like to simulate them all at once, but then i don't know how to get the information.
can somebody help?
thanks and greets
IrieConqueror is offline   Reply With Quote
Old   April 3, 2020, 06:50
Gert-Jan
Gert-Jan will become famous soon enough
In Pre, got to Output Control. There you define .csv-files that the solver creates at the end of each particle track. It allows you to control the location (outlet, wall1, wall2, .. ) and the variables. One the variables can be the particle diameter.
Then open the csv in your spread sheet and sort on diameter.
Gert-Jan is offline   Reply With Quote
Old   April 6, 2020, 07:29
Nice! Thank you
Old   April 7, 2020, 07:24
I tried to solve the "problem" in two different ways.
First i set every diameter individually in PRE and checked the .out-file.
After that I did what Gert-Jan suggestet.
The results are similar but not identically. Are there differences between "mean particle diameter" and "the specified diameter" (in PRE)?
I used the same .def-file for both simulations, just changed from "discrete diameter distribution" to "specified diameter".
Any ideas?
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 02:23
How to track Particle Deposition in a particular region? kharatsandeep99 FLUENT 0 December 9, 2016 13:11
Assign mass fraction to a region in the domain for particle tracking Sahar FaPerhu FLUENT 0 April 9, 2013 13:02
Particle count kingjewel1 FLUENT 0 November 30, 2009 04:50
PRE: Particle Injection Region as f(temperature) Daniel CFX 0 February 19, 2009 16:09
