April 13, 2020, 04:56 |
Coupling between CFX and Matlab
Martin Rønnov Andersen
Rep Power: 7 |
Hi!
Is there a way to couple CFX and Matlab? I have an optimization problem where I would like to perform all flow simulations in CFX and run the optimization through Matlab. I intend to use Matlab as the "Master" and CFX as a "Slave" - if that makes sense. Thank you! |
April 13, 2020, 05:50 |
Rep Power: 143 |
What level do you want to do the coupling?
If you want CFX to do the simulations, output a result and matlab processes the result, and generates a modified input file which is passed back to CFX: This type of coupling is straight forward and can be done using the command line interface. You drive CFX-Pre and CFX solver from the command line from Matlab, and it runs inside a matlab script. If you want matlab to couple into the simulation running in CFX then things are MUCH harder. I hope you don't want to do this.
April 13, 2020, 19:13 |
Rep Power: 7 |
Hi Glenn, thank you for the answer!
Yeah, basically as you write: Run the simulation in CFX --> Extract the result and put into Matlab --> Generate a new input file --> Put into CFX --> Run again. And the loop then continues, until an or several optimum points have been generated/found. The idea is to use a genetic algorithm in Matlab. Do you have an example of something remotely related to this? This is my first time using the command line interface. |
April 13, 2020, 19:58 |
Rep Power: 143 |
The command line interface of CFX is described in the documentation. Or you can just fire up a command line and ask for help. The commands are cfx5solve and cfx5pre, and they both have a -help option.
cfx, coupling, matlab, optimization |
Creating a CFX Simulation using a MATLAB Interface | amsys | CFX | 1 | February 11, 2019 09:57 |
Integrating/Interfacing cfx with Matlab | Darren Leong | CFX | 34 | February 9, 2019 07:33 |
How to control CFX with Matlab | Behnam.Esfandiar | CFX | 4 | April 29, 2014 09:02 |
Cfx - matlab | camilo_costa | CFX | 15 | October 14, 2013 17:18 |
Call CFX from MATLAB | alikhube | CFX | 7 | December 30, 2012 06:35 |
