Getting rid of weird Tet regions in ICEM?
Old   June 8, 2006, 13:34
Default Getting rid of weird Tet regions in ICEM?
Chebeba
I sometimes get regions of large size and strange aspect tets occuring in the middle of the volume mesh. They appear randomly, and the sizes are larger than Global Max Size or any Densities in the area. (Using "Tetras from Surface Mesh" with a premeshed boundary layer in ICEM 10 ServicePack2).
Sometimes just remeshing makes them go away, but now I'm stuck with a model that doesn't. Anyone knows any tricks to get rid of them?
Here is an example:
Old   June 8, 2006, 14:51
Default Re: Getting rid of weird Tet regions in ICEM?
Joe
Are you smoothing the mesh at all?
Old   June 8, 2006, 15:49
Chebeba
Well it doesn't help, once these "blobs" of too large tets are in there, smoothing doesn't make them go away.
The surface mesh is smoothed before growing the prisms of course.
Old   June 8, 2006, 17:35
Joe
Do you use a smooth transition factor when doing the tet volume mesh? If so, what value do you specify?
Old   June 9, 2006, 04:24
Chebeba
1.05 in this case. Or 1.1 or 1.06, I made different attemtps since the problem is intermittent and sometimes goes away when you remesh. But in this case it doesn't want to /C
Old   June 9, 2006, 06:46
Joe
Do you get the problem when the smooth transition factor is unset?
Old   June 13, 2006, 16:20
Chebeba
"Smooth Transition" is only available in "From Geometry" mode. I am using "From Surface Mesh", which doesn't have this parameter.
Old   June 14, 2006, 08:15
myron
You can try building a mesh subset of those elements and a few elements around them. Then you can remesh just that subset to see if that fixes the issue. Essentially it throws out that subset, then re-meshes based on the elements around the subset.
Old   June 14, 2006, 17:49
In my experience these sort of problems are caused by mesh smoothing. The default smoothing options sometimes goes bezerk and makes horrible little bits like Chebaba is getting.
My suggestion would be to remesh the original tet mesh again and use it without smoothing, or if you must smooth do a two step smoothing where you smooth the surface elements only with a laplace smoother (with the volume elements floating) then freeze the surface elements and do a normal smooth on the volume elements.
You can also tweak the smoother by adjusting the quality to smooth up to parameter and the quality critereon - maybe an aspect ratio based criteria would help here.
How to define multiple fluid regions in icem user0314 ANSYS Meshing & Geometry 6 June 2, 2020 00:28
Problem with ICEM and Fluent: Automatically created Regions within the domain sandmike_83 ANSYS Meshing & Geometry 0 September 24, 2010 05:42
[ICEM] Trying to create a similar prostar tet mesh using ICEM cfdengineer ANSYS Meshing & Geometry 2 March 13, 2010 18:02
how to define different regions in icem ? Hammam CFX 3 July 9, 2007 12:56
ICEM tet mesh output jemteo CFX 1 August 15, 2004 18:34
