June 12, 2006, 09:20 |
Euler equation
i would like to know whether it is possible to solve fluid flow problem with the help of Euler equation model (non-viscous fluid)in CFX. Thank You, Petr. |
June 12, 2006, 09:39 |
Re: Euler equation
Set the flow to laminar and the viscosity to a very small number.
June 12, 2006, 09:55 |
Re: Euler equation
Thank You.
One more question. Is it easy to prescribe viscosity ? Sorry for this question, but at recent time i am not able to check it (once more again sorry). Petr. |
June 12, 2006, 10:23 |
Re: Euler equation
Yes. Create a new material in the material editor and set the transport properties as needed.
For a pseudo-Euler analysis dont set the viscosity to exactly 0, just a suitably small value. |
June 12, 2006, 10:25 |
Re: Euler equation
Thank You Joe and CFD Man.
October 16, 2012, 11:57 |
su yunde
Rep Power: 13 |
hello!
i am conducting a simulation through euler equation in cfx and meet some questions. i set a very low Dynamic Viscosity value, the 'laminar' turbulence model option .besides, i also set the 'Free Slip Wall' option at all walls. however, i get the following message in cfx solver: +--------------------------------------------------------------------+ | ERROR #002100004 has occurred in subroutine Out_Scales_Flu. | | Message: | | The Reynolds number is outside of the range expected based on the | | Option selected for the TURBULENCE MODEL. Check this setting, | | the values of the properties, mesh scale, consistency of units | | and solution values in the input file. Execution will proceed. | +--------------------------------------------------------------------+ does this message effects the result? thank you for your reply! |
October 16, 2012, 18:26 |
Rep Power: 143 |
It is just a warning. You can ignore it - but make sure you know that the flow is in fact laminar.
October 17, 2012, 00:19 |
su yunde
Rep Power: 13 |
thank you, ghorrocks!
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Jacobian of 1D Euler Equation of Gas Dynamics | Simplicity. | Main CFD Forum | 3 | September 6, 2011 14:12 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Linearized Euler Equation | vasanth | Main CFD Forum | 0 | May 30, 2004 15:25 |
