Momentum Source Convergence
Old   June 15, 2006, 17:04
Default Momentum Source Convergence
Doug
Hi. I'm trying to simulate air flow through a fan by adding a general momentum source to a subdomain, however I am having convergence problems.
Convergence of v-momentum eventualy causes divergence of u-,w- momentum equations (at about max-v-mom= 1e-02).
(using upwind, timestep auto. but reducing t results in same)
Seems the worst residuals are right at the boundaries of the subdomain where the source is added (1e-02). But Grid refinement seems not to help. Overall velcity field looks realistic (vmax approx 5m/s).
Anyone have any experience / problems / ideas with adding momentum sources?
axial component: -500 * parabolic_distribution r component: 0 theta comp: 0
Momentum source component: -1e+05
NOT redistributed in Rhie Chow <-- seems to do nothing
NOT incl. Coeff. in Rhie Chow <-- seems to do nothing
Rotation Axis: GlobalY
Old   June 16, 2006, 05:54
Default Re: Momentum Source Convergence
Joe
You should not be using the upwing scheme. Are you sure your source size calculations are accurate? Manual contains a good section on dealing with convergence issues "Advice on flow moddeling".
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 06:10
Momentum source Siva.K CFX 0 July 10, 2008 05:49
how to define momentum source charonly FLUENT 1 September 8, 2006 03:45
Mass transport, momentum source and turb K.E CFDtoy FLUENT 0 April 24, 2006 00:33
