dear all
I am doing analysis on centrifugal blower. The analysis is not getting convergence for some changes in boundary conditions like mass flow at outlet.the maximum residual value for this case is 7e-04. but required one is 1E-04. i have checked converged results at different values of maximum residual value. the result is not much varing in between 8E-04 to 1E-04. now my question is, can i take the results at residual of 8e-04 as final results? if anybody know the answer please give reply. thanks sarath |
Dear Sarath,
I had similar problems interms of convergence with my case (Axial Compressor). I was recommended, to specify Static Pressure as an outlet condition instead of the outlet massflow rate. This change worked in my case and I was able to effectively minimize convergence issues. Further refinements were made to the geometry and grid which gave me results, I was looking for !!! If my memory has not let me down, it is highly recommened to have an RMS of 1E-06 (design condition) for any turbomachinary simmulation in CFX 10.0. Also if you search using the word "convergence" as a keyword within CFX 10.0 manual (mainly in CFX Pre and Solver PDFs), it should lead you to boundary setting and solver setting details for better convergence with accuracy. I hope this piece of information helps you..... Good luck. Best regards, Arjun |
better to reach RMS at 1e-6 for convergence.
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Convergence difficulties with 2d mixerGGI | louisgag | OpenFOAM Running, Solving & CFD | 5 | February 6, 2009 12:05 |
Convergence difficulties | Freeman | FLUENT | 1 | November 28, 2005 15:42 |
