Convergence Difficulties
Old   August 19, 2006, 21:45
Default Convergence Difficulties
sarath
dear all
I am doing analysis on centrifugal blower. The analysis is not getting convergence for some changes in boundary conditions like mass flow at outlet.the maximum residual value for this case is 7e-04. but required one is 1E-04. i have checked converged results at different values of maximum residual value. the result is not much varing in between 8E-04 to 1E-04.
now my question is, can i take the results at residual of 8e-04 as final results?
if anybody know the answer please give reply.
thanks sarath
Old   August 21, 2006, 06:22
Default Re: Convergence Difficulties
ARJUN
Dear Sarath,
I had similar problems interms of convergence with my case (Axial Compressor). I was recommended, to specify Static Pressure as an outlet condition instead of the outlet massflow rate. This change worked in my case and I was able to effectively minimize convergence issues. Further refinements were made to the geometry and grid which gave me results, I was looking for !!!
If my memory has not let me down, it is highly recommened to have an RMS of 1E-06 (design condition) for any turbomachinary simmulation in CFX 10.0. Also if you search using the word "convergence" as a keyword within CFX 10.0 manual (mainly in CFX Pre and Solver PDFs), it should lead you to boundary setting and solver setting details for better convergence with accuracy.
I hope this piece of information helps you.....
Good luck.
Best regards, Arjun
Old   August 21, 2006, 08:35
Bian
better to reach RMS at 1e-6 for convergence.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Convergence difficulties with 2d mixerGGI louisgag OpenFOAM Running, Solving & CFD 5 February 6, 2009 12:05
Convergence difficulties Freeman FLUENT 1 November 28, 2005 15:42
