Two questions about data analysis
Old   August 31, 2006, 09:52
Default Two questions about data analysis
Felix
Hi there, I have two small questions for you. I hope you can help!
____________________
First, I would like to know if it is possible in a macro to extract only the name of the analysed file (i.e. "result.res") without the whole path? I currently use the line below which gives me the name including the unwanted path (i.e. "...\path\folder1\folder2\result.res"):
! $sim = getValue("DATA READER", "Current Results File")
Second, I would like to produce some clearly understandable image files and would need to create a "surface of velocity". Let me explain. I created in CFX-Post a plane on which I can add normal velocity vectors. What I would like to do is to create a 3D surface joining the tips of these vectors. Is that possible?
Thaks a lot for your help,
Felix
Old   August 31, 2006, 10:11
Default Re: Two questions about data analysis
Joe
1) Google: "perl strip path"
2) Covered in this forum about 2 months ago ... search.
Old   August 31, 2006, 10:14
longbow
To answer your second question, a user surface may achieve what you want to do.
USER SURFACE: User Surface 4 Offset Direction = 0 , 0 , 1 Offset Mode = Variable Offset Type = Translational Offset Variable = Velocity w Option = Offset From Surface Surface Name = SURFS 1 B B END
Old   August 31, 2006, 10:53
Felix
Ok, thanks a lot to both of you.
Felix
Old   September 4, 2006, 05:33
Michael B
http://www.cfd-online.com/Forum/cfx_...cgi?read=15965
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 13:50
matching variable data with grid point data anfho OpenFOAM Programming & Development 0 May 6, 2011 15:28
[General] paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 18:01
best software for the analysis of pump data RKR Main CFD Forum 0 May 22, 2008 07:49
