Distribuited Parallel
Old   October 10, 2006, 03:16
Default Distribuited Parallel
massimo
Hi, I have a problem with the PVM distribuited parallel. The machine configuration is:
1. 2xOpteron 260 8Gb Ram 2. 2xOpteron 260 8Gb Ram 3. 2xOpteron 260 8Gb Ram
(all the machine have WinXp64 and identical software configuration)
when I start the simulation I receive the message:
PVM-error flag from notifying missing partition: -31
Anyone can help me for this problem?
Thank's in advance
m.
Old   October 10, 2006, 09:40
Default Re: Distribuited Parallel
Bian
Are you using CFX11 P5? If so, the distributed parallel is not working for XP64. Download P6 or later version, but the distributed parallel scalability is not good.
I would be very interested in the speed of your machines. Could you run the benchmark file coming with CFX and report the parallel speed here? Thanks.
Bian
Old   October 10, 2006, 10:46
massimo
Hi, no I'm using CFX 10. I run the benchmarck as soon as possible... Thank's Bye m.
Old   October 10, 2006, 22:08
HekLeR
Windows parallel scales perfectly fine for me. You must be doing something wrong setup wise or how you are measuring it.
Old   October 11, 2006, 06:24
massimo
Is working fine the PVM with XP64?
Old   October 11, 2006, 08:38
Bian
CFX10 SP1 for XP4 distributed parallel should work. But I got very poor speed gain even for local PVM parallel. Can you get good scale for local PVM? MPICH would be much better. My machine is woodcrest CPU, so very interested in your AMD CPU speed.
Old   October 11, 2006, 22:12
HekLeR
32 bit cfx10 works
64 bit cfx11 beta versions do not yet. you might ask support for an update.
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 15:52
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
Cumulative continuity error large in parallel simulations xiao OpenFOAM 3 March 7, 2011 04:13
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
