November 25, 2020, 04:11 |
Error Message during Simulation
Sara
Rep Power: 5 |
November 25, 2020, 04:22 |
Rep Power: 143 |
Only the first error is important. All the others are caused by the first one.
But I have no idea what caused the first error, and you have not explained anything about what you are doing so I cannot say. I would run it again to see if it happens again, and if you want us to help post your full output file and an image of your geometry.
November 26, 2020, 04:24 |
#3 | |
Sara
Rep Power: 5 |
message Inkederrorsave_LI.jpg |
November 26, 2020, 04:30 |
#4 | |
Sara
Rep Power: 5 |
No problem, I can do that. How to extract the full output file? |
November 26, 2020, 04:53 |
Rep Power: 143 |
Before we look at your output file - have you checked you have not run out of disk space like the error message says?
November 26, 2020, 05:23 |
Sara
Rep Power: 5 |
I deleted some files in the directionary and now I hope it will run and complete the process. I definitely think it has nothing to do with the physics in my model.
November 26, 2020, 08:44 |
Sara
Rep Power: 5 |
November 26, 2020, 15:56 |
Gert-Jan
Rep Power: 27 |
1) I think the message is quite obvious. One of your contours, vectors, or similar object is referring to something that does no longer exist. Probably you renamed or removed a boundary in Pre?
2) This question has nothing to do with your main topic. Better start a new query. Then it is also easier to find it by other people that face the same problem in the future. 3) Since your name is knowledge, I suggest you gain some by doing a little research yourself. Better change things and see how the system repsonds. In this way you gain the most knowlegde. |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 09:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
