Multistage simulation
Old   October 24, 2006, 08:48
Default Multistage simulation
Flavio
I'm working with a stage of a multistage pump. Supposing inlet flow to be axial, the outlet flow is obviously carachterized by a considerable rotational component. Considering that outlet flow coincides with the inlet flow of the next stage, the simulation now exposed is to be considered representative of the first stage only. Knowing that the multistage pump mounts around 70 stages in series, it is necessary to simulate the flow in the intermediate stages. A solution i considered is to save the outlet flow and introduce it "manually" as inlet condition for a secondary simulation, and so on until a sort of convergence is reached.
My question is: does in CFX 10.0 exist a feature that allows me to operate automatically this kind of iteration and this kind of "convergence check"?
Thanks.
Old   October 24, 2006, 09:12
Default Re: Multistage simulation
Robin
If you run these separately, there is no automatic way to make sure it converges. The "automatic" way is to set this up as a multi-stage calculation, solving all stages simultaneously, although 70 stages may make for a large calculation.
-Robin
Old   October 26, 2006, 22:25
TB
I would imagine that you need to set the boundary condition between interface. Solution convergence could be affected if the boundary condition is not right. Error will just propagate in the next stage. If computational resources are not a concern, I'll suggest you to simulate the entire domain in one go.
Old   October 27, 2006, 09:19
Robin
You can ouptut a BC profile from the outlet of the upstream component and apply it to the inlet of the downstream component. All of this could potentially be scripted and put in an automated loop.
-Robin
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Axial fan simulation in UG/NX 7.5 fan123 Main CFD Forum 2 April 23, 2011 08:22
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
