iMUSIG setup
Old   December 6, 2020, 10:21
Default iMUSIG setup
Geoff
Geoff67 is on a distinguished road
Does CFX automatically connect the velocity groups for iMUSIG?
I have run the MUSIG model for a single velocity group and got a reasonable result. When I try to add a second velocity group, it solves fine. However, the results don't make sense. I have a size fraction of 90% in the largest bubble size of the first velocity group, yet no mass is entering the second velocity group.
My set up in pre is as follows:
Phases
-water (continuous)
-air1 (polydisperse)
-air2 (polydisperse)
In the polydispersed fluids tab I create 2 MUSIG fluids
-airVG1 for the first velocity group, air1, diameters 0-6mm
-airVG2 for the second velocity group, air2, diameter 6-12mm
-both are 'Homogeneous MUSIG' I do not see an option for 'Inhomogeneous MUSIG'
In Fluid pairs tab I configure air1|water, air2|water as I normally would. There is no air1|air2 pair so I thought CFX automatically linked them. Now I do not know if this is the case.
I am using the standard CFX breakup and coalescence models.
I have read the CFX documentation but I haven't found specific instructions on setting up iMUSIG.
Geoff67 is offline   Reply With Quote
3 Stage axial compressor CFX Setup knixxor CFX 9 November 29, 2016 13:38
2D Glass Melt Simulation Setup marmz FLUENT 5 October 9, 2016 15:25
[OpenFOAM.org] OpenFOAM Cluster Setup for Beginners Ruli OpenFOAM Installation 7 July 22, 2016 04:14
[ICEM] surface/curve mesh setup Studi ANSYS Meshing & Geometry 15 November 12, 2014 00:32
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
