Rough wall at a nonoverlap bc: Solver exited with return code 1 |
December 15, 2020, 07:05 |
Hello everyone,
I am having a problem with simulating a centrifugal compressor with a recirculation device. I have a rotating impeller domain and a stationary recirculation domain and those two are connected by a frozen rotor interface. At the impeller shroud, I activated the "Nonoverlap Conditions" and used a Counter Rotating Wall which is smooth. This works just fine. But as soon as I make it a rough wall and add a Sand Grain Roughness to it, I immediately get the error message "Ansys solver exited with return code 1". The out-file says the following: Details of error:- ---------------- Error detected by routine PEEKCS CDANAM = HOW CRESLT = NONE Current Directory : /FLOW/BOUNDCON/ZN1/BCP9/NOVARIABLES/RGH +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine MAKDAT CDANAM = LVAR CDTYPE = INTR ISIZE = 174 CRESLT = OLD Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. Does anyone have an idea what might be the problem? Thanks and regards, Jonas |
December 15, 2020, 14:45 |
Rep Power: 143 |
Please attach your output file.
December 17, 2020, 13:13 |
Here is the out-file. I replaced some sensible information with ... Thanks and regards, Jonas |
December 17, 2020, 16:47 |
Rep Power: 143 |
The output file shows it crashes just after the monitor points are initialised. It seems to be looking for a variable associated with one of your monitor points and it cannot find it. Check that your monitor points are properly defined and are using the correct variable name (including case).
December 18, 2020, 10:16 |
Rep Power: 32 |
I have seen the same error in recent releases, and you may have to contact ANSYS CFX support for a temporary workaround.
Do not recall if you need a modified configuration file.
December 18, 2020, 13:18 |
Gert-Jan
Rep Power: 27 |
Like 'yplus' versus 'Yplus'
cfx, compressor, nonoverlap, ported shroud, rough wall |
Particle tracking in CD nozzle error:The ANSYS CFX solver exited with return code 4 | lcui | CFX | 0 | September 9, 2019 20:58 |
ANSYS CFX solver exited with return code 2 | vmlxb6 | CFX | 6 | June 22, 2017 18:01 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
