mesh from Workbench Simulation to Cfx Pre?
Old   November 6, 2006, 08:56
Default mesh from Workbench Simulation to Cfx Pre?
Dai
Is it possible to transfer the mesh from Ansys Workbench simulation to CFX Pre? Can I mesh my geometry in "workbench simlation" and define the physical problem in CFX Pre? Which format?
Old   November 8, 2006, 11:25
Default Re: mesh from Workbench Simulation to Cfx Pre?
Robin
You could write your mesh to an ANSYS input file then load it into Pre. At version 11 you'll be able to load the .dsdb file directly into Pre.
-Robin
Old   November 9, 2006, 04:54
Dai
Thank you Robin, your suggestion sounds great. Till now I have no iddea how to open the Workbench simulation mesh in Ansys as well - Ansys does not support .dsdb files, does it? Daiga
Old   November 9, 2006, 15:08
Robin
To load your Simulation into the old ANSYS gui, just select it on the project page and follow the links on the left hand side. There should be one about opening the environment.
-Robin
Old   November 10, 2006, 04:37
Dai
Thanks Robin a lot! Daiga
Old   November 10, 2006, 08:50
Default Re: mesh from Workbench Simulation -> Ansys ->CFX
Dai
Dear Robin! Ansys opens my mesh ans show each region in different colour, but it does not recognize any volume, surface... - after mesh export through cdwrite,db... I can import the mesh in CFX, but I am not able to choose any region (in Workbench simulation the geometry of part consisted of 3 regions),face, interface...Do I need to define surfaces and volumes again in Ansys??? Daiga
Old   November 11, 2006, 12:19
Robin
For now, yes. Although the regions might come through if you create named selections in Simulation first (not sure, but you could easily test this). When version 11.0 comes out you'll be able to create 2D regions directly in Pre.
simulating 2D airfoil mesh in CFX iffy ANSYS Meshing & Geometry 7 January 24, 2017 03:05
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
running 2D airfoil mesh in CFX iffy ANSYS 1 February 13, 2011 21:35
Mesh used for Combustion Simulation Stein CFX 5 May 14, 2009 18:24
CFX mesh & ICEM mike CFX 3 April 27, 2006 15:27
