November 6, 2006, 08:56 |
mesh from Workbench Simulation to Cfx Pre?
Is it possible to transfer the mesh from Ansys Workbench simulation to CFX Pre? Can I mesh my geometry in "workbench simlation" and define the physical problem in CFX Pre? Which format?
November 8, 2006, 11:25 |
Re: mesh from Workbench Simulation to Cfx Pre?
You could write your mesh to an ANSYS input file then load it into Pre. At version 11 you'll be able to load the .dsdb file directly into Pre.
-Robin |
November 9, 2006, 04:54 |
Thank you Robin, your suggestion sounds great. Till now I have no iddea how to open the Workbench simulation mesh in Ansys as well - Ansys does not support .dsdb files, does it? Daiga
November 9, 2006, 15:08 |
To load your Simulation into the old ANSYS gui, just select it on the project page and follow the links on the left hand side. There should be one about opening the environment.
-Robin |
November 10, 2006, 04:37 |
Thanks Robin a lot! Daiga
November 10, 2006, 08:50 |
Re: mesh from Workbench Simulation -> Ansys ->CFX
Dear Robin! Ansys opens my mesh ans show each region in different colour, but it does not recognize any volume, surface... - after mesh export through cdwrite,db... I can import the mesh in CFX, but I am not able to choose any region (in Workbench simulation the geometry of part consisted of 3 regions),face, interface...Do I need to define surfaces and volumes again in Ansys??? Daiga
November 11, 2006, 12:19 |
For now, yes. Although the regions might come through if you create named selections in Simulation first (not sure, but you could easily test this). When version 11.0 comes out you'll be able to create 2D regions directly in Pre.
simulating 2D airfoil mesh in CFX | iffy | ANSYS Meshing & Geometry | 7 | January 24, 2017 03:05 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
running 2D airfoil mesh in CFX | iffy | ANSYS | 1 | February 13, 2011 21:35 |
Mesh used for Combustion Simulation | Stein | CFX | 5 | May 14, 2009 18:24 |
CFX mesh & ICEM | mike | CFX | 3 | April 27, 2006 15:27 |
