How to import gtm-file into icem?
Old   December 5, 2006, 06:04
Default How to import gtm-file into icem?
Aloise
I have a gtm-file, that can be read in cfx-pre. But I need to modify the coordinate-axis direction and the names of the mesh-surfaces.
How can I reimport the gtm-file into ICEM V10 to make the modifications?
Thanks, Aloise
Old   December 5, 2006, 09:15
Default Re: How to import gtm-file into icem?
Robin
Write a def file out of Pre, then load the def file into ICEM CFD. Just create a dummy domain to do so.
-Robin
Old   December 5, 2006, 13:09
Aloise
Thanks,
I did it that way, but I thought there must be another one.
-Aloise
Old   December 5, 2006, 13:17
Aloise
Now I`m importing the def-file via file-import mesh-from CFX5 But do you know what "Set face parts from": BC Patches or Surface means?
The entry in the helpfile didn`t help me a lot.
-Aloise
Old   December 10, 2006, 19:24
Robin
There are two types of 2D regions in the def file, the boundary regions and your mesh regions (which may or may not be used for the boundar regions). The dialog is simply asking which you want to appear in ICEM CFD.
-Robin
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
