Merge Nodes automatically
Old   December 6, 2006, 03:47
Default Merge Nodes automatically
Timmy
Hi Guys,
I have a small problem with ICEM CFD 10.0 I have two different 2D surface meshes (Tri) and want to merge them. Is there any possibility to merge the nodes at their interface automatically? I only found the "merge nodes" option that provides to do this manually.
Thanks for your help,
Timmy
Old   December 6, 2006, 08:51
Default Re: Merge Nodes automatically
myron
If the nodes are coincident (or very close within a tolerance) you can merge by specifying a tolerance - then select the whole set of nodes to merge. If they are not consistent at all - there's really no way to merge only surface meshes.
SIMPLE algorithm SamR Main CFD Forum 19 April 26, 2019 13:06
Scale-Up Study in Parallel Processing with OpenFoam sahm OpenFOAM 10 April 26, 2010 17:37
assemble the mesh feixiangniao ANSYS Meshing & Geometry 2 March 20, 2010 02:39
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
