February 19, 2021, 04:04 |
Axial Flow Fan Performance Map
Zero
Rep Power: 6 |
Hello everyone, I have simulated an axial flow fan in CFX, and I'm trying to get the performance map for that fan (4 or 5 curves). So I need to run multiple cases for each curve (constant rotational speed) and either change the mass flow rate, or the pressure difference. Since changing the mass flow rate is a more secure option than changing the outlet pressure in order to get the ΔP (that would require guessing and maybe the map will not be correct), I'm going with mass flow outlet BC.
My question is, how do I change the mass flow rate for constant rpm since the setup has a constant cross section area, constant density (it's a small scale low speed fan) and each fan draws constant mass flow (hence axial velocity) for constant rpm. Thank you in advance. |
February 19, 2021, 07:32 |
Rep Power: 32 |
What release version are you currently using?
February 19, 2021, 08:46 |
Zero
Rep Power: 6 |
February 19, 2021, 09:22 |
Rep Power: 32 |
The creation of performance maps is a recent feature, and reduces the pain of generating them. My advice is to upgrade to a more recent version, 2020Rx, or 2021R1
Using the feature, you only need to specify the range of the variables of interest, say mass flow = 0.1, 0.3, 0.5 [kg/s] rpm = 5000, 5500, 6000 [rpm] ... = ... [ ] and submit the simulation. Once finished, you can open the results file in CFD-Post and look at the performance map directly, including the different speed lines, and contours
February 19, 2021, 11:42 |
#5 | |
Zero
Rep Power: 6 |
Ok I will try your suggestion. Thank you. |
February 19, 2021, 15:22 |
Rep Power: 32 |
CFD post cannot load results-Error appeared? | mariam.sara | ANSYS | 9 | September 17, 2018 15:23 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Axial Flow Pump Performance Prediction | bharathn | CFX | 1 | February 25, 2013 17:51 |
urgent pressure condition for axial flow fan | VIPUL | FLUENT | 0 | October 24, 2008 02:01 |
How to model flow of centrifugal fan? | Peter | Main CFD Forum | 0 | April 2, 2008 06:07 |
