February 28, 2021, 05:27 |
Boundary conditions in a pipe
Daria
Dear All,
I'm trying to proceed the simulation in a syphon. I'd like it to be transient simulation of two fluid - water and air. I tried to set opening in inlet with mass and momentum option - opening pres. and dirn and the same option for outlet but there is a warning "the solver failed with a non-zero exit code:2". The same warning occurs when I tried to set opening in inlet and boundary type in outlet. I have no idea where is a problem and how to fix i :< |
February 28, 2021, 06:23 |
Sasan Ghomi
Rep Power: 14 |
Why are you using Opening Boundary condition in Inlet Boundary? Switch to Inlet B.C and fix the mass flow rate. Also, it is better not to force the direction of flow in the outlet boundary condition.
Best regards, Sasan Ghomi |
February 28, 2021, 08:20 |
Gert-Jan
Rep Power: 27 |
This is not a simple calcultion. The boundary orientation and ssecification need to be defined with great care. So, please show the exact geometry and your BC settings (= upload the output file).
boundary condition, cfx, transient 2d |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
