April 14, 2021, 00:35 |
Top Wall Opening Behaves as No Slip?
Kira
Rep Power: 8 |
I ran a simulation of air passing through a rectangular box where the top wall was set as an opening. When I look at the velocity in the wall normal direction, the velocity at the top goes to zero. Any ideas as to why this might be happening? I have laminar flow and no heat transfer, so not sure what would be slowing down the flow near the top. |
April 14, 2021, 04:34 |
Rep Power: 143 |
The default opening option does not allow flow parallel to the boundary, this appears to be what you are seeing. The Entrainment option allows flow parallel to the boundary, but can be harder to converge. This is all described in the CFX documentation.
April 14, 2021, 10:56 |
Kira
Rep Power: 8 |
Oh, sorry, I should have mentioned that I was using an opening with Static Pressure and Direction, normal to the boundary, 0 Pa. Should I consider switching to Entrainment?
April 14, 2021, 13:46 |
Erik
Rep Power: 23 |
If your real opening boundary has velocity tangent to the opening plane, then most likely yes. You want your boundary condition to be as close to realistic as possible right?
A sensitivity analysis would show whether it makes a difference of not to your result of interest. |
April 14, 2021, 18:38 |
Kira
Rep Power: 8 |
Thank you Glenn and Erik for those points. You are both correct; it does not make much sense to have specified the flow normal to the boundary. When solving flat plate problems, we have the freestream velocity parallel to the boundary.
I will try the other boundary condition and report back. |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
opening sims as a wall. | Curran919 | CFX | 8 | March 19, 2012 21:31 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
