April 23, 2021, 09:31 |
Nusselt CFX Post
Mercurial
Rep Power: 5 |
Hi guys,
I'm trying to calculate Nusselt on the heat wall. I wrote Expression and use it to show the Nusselt, but it haven't the distribution around cylinder, whereas I use Fluent, I have Nu distribution around cylinder. I don't understand why. My boundary condition is heat flux on wall, velocity+temperature inlet, gauge pressure outlet. My expression: Tdifferent=massFlowAve(Temperature)@outlet-massFlowAve(Temperature)@inlet Tbulk=massFlowAve(Temperature)@inlet +(x*0.4846[m])/0.872[m]*Tdifferent h=5000[W m^-2]/(Temperature-Tbulk) Nu=h*0.0235[m]/0.0254[W m^-1 K^-1] Nuave=ave(Nu)@heatwall ( I use ) Please someone help to understand and fix this error. |
April 23, 2021, 12:08 |
Rep Power: 32 |
You have to simplify your debugging process into your critical pieces.
I suggest to: 1 - Make a contour of Tbulk, is the distribution linear as you expected? 2 - are the minimum/maximum values as you expect 3 - Make a contour of (Temperature - Tbulk), is the distribution as you expected? Recall that for uniform heat flux boundary condition the difference between wall temperature and bulk temperature becomes constant once the flow is thermally developed; otherwise, the contour should be closer together from the inlet and spreading further along along the flow direction 4 - Now you get the idea; therefore, "rinse and repeat" using h, then Nu Hope the above helps,
CFX Pre & Post Startup Error | vigges | CFX | 12 | March 17, 2023 03:30 |
Accessing cell values (CFX Pre and CFX Post) | brahmarishiraj | CFX | 14 | June 24, 2014 19:12 |
CFX post legend modification | mactech001 | CFX | 3 | December 25, 2011 22:12 |
CFX Post export problem | jeff_F | CFX | 0 | August 17, 2009 21:25 |
CFX Post processing | aditya | CFX | 1 | July 6, 2008 12:09 |
