Directional loss model
Old   January 30, 2007, 12:20
Default Directional loss model
Claudia
I would like to simulate a porous plate inside a duct. I know all dimensions. The plate is 51% open. I would like to use the Directional Loss Model. I'm not really sure what CFX want to know in this model. Is the "permeability" the part of the plate which is open (open area)? And what is the "Resistance Loss Coefficient"? I only know the zeta value for the plate. I know that it isn't the same.
Thanks for help
Claudia
Old   January 30, 2007, 12:54
Default Re: Directional loss model
Robin
Hi Claudia,
This is covered in the documentation.
-Robin
Old   January 31, 2007, 13:07
Claudia
Hi Robin,
I know that there is something written in the documentation, but not for the questions I have. Maybe I have some problems to understand. So I need help to understand what kind of value I should write at "permeability" and "resistance loss coefficent".
Thanks
Old   February 8, 2007, 20:15
Reza Farahani
Hi Claudia,
Permeability depends on the type of porous medium that you have. The directional loss is the loss associated with the porous medium which is included in the general momentum equation as a source term. If you read ANSYS CFX-Solver, release 10.0: Theory Page 66, you will understand how CFX calculates the loss coefficients. But in your case, based on the viscosity of the material you have chosen and the permeability, you wont need to assign any value to the coefficients unless you want them to be specific values.
hope this helped, Reza
single directional message transmit in parallel model su_junwei OpenFOAM Programming & Development 1 December 17, 2009 07:00
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Kato-Launder model sam Main CFD Forum 13 September 21, 2006 10:15
