CFX - the introduction of a wall into an air duct. |
June 24, 2021, 08:16 |
#21 |
Rep Power: 32 |
For example,
if ( probe(Velocity)@MyPointofInterest < Tiny, ... , ... ) I think you should use some tiny value, and not 0 exactly. We are dealing with convergence and plenty of round-off here, are you certain it can reach 0 exactly? If you are, go for it; otherwise, the expression is just consuming cpu cycles. Keep in mind, that Velocity is always positive since it is the magnitude of the vector in that expression. When dealing with components or other scalars, you may want to use abs( ) if ( abs (probe (MyVar)@MyPointofInterest)) < Tiny, .. ) or more generically if (abs (probe(MyVar)@MyPointofInterest) - MyTargetValue) < Tiny, ..., ..) Hope the above helps,
June 24, 2021, 13:42 |
#22 |
AH
Rep Power: 13 |
I'm looking there, I couldn't find anything, was hoping to put his in an 'if' condition.
Also, I'm looking for away where I can apply a load on a boundary condition. But not to go into the obvious Static Structural ANSYS tool. Thanks. |
June 24, 2021, 18:35 |
#23 |
Rep Power: 143 |
What version of CFX are you using?
I do not understand your boundary condition comment. What "load"? Load of what?
June 25, 2021, 04:06 |
#24 |
AH
Rep Power: 13 |
Thanks Opaque, but what command stops solver? What shall I enter in the true return condition?
if ( probe(Velocity)@MyPointofInterest < Tiny, ... , ... ) ---- Thanks Ghorrocks, its a boundary condition I have created on the air-duct, about 100 mm diameter. This will have a 10 kg load on it (100 N). ANSYS 2021 academic, CFX. |
June 25, 2021, 05:01 |
#25 |
Rep Power: 143 |
I told you in post #20 how to stop a simulation with a condition. If you don't understand a comment ask for it to be explained, do not ignore it.
CFX-Pre, Solver Control/Basic Settings/Interrupt Control. You can then set how the interrupts work (whether they AND or OR), and any user defined conditions (like yours would be). Look in the CFX-Pre manual section 22.1.1.6 for details. You cannot put 100N load on a fluid without further information. The load needs to act on a surface, or be a thrust load, or some other action - and in all these cases you also need to define an area, object or surface for it to act on. So how do you intend to apply your load?
June 25, 2021, 17:12 |
#26 |
AH
Rep Power: 13 |
I did look at this interrupt control, but did not understand how to utilize an if condition.
Regarding the load condition in CFX, the load acts on the air duct surface, sheet metal. It is a boundary condition I have created in space claim, an area 200 mm dia with a load acting on it. |
June 25, 2021, 21:14 |
#27 |
Rep Power: 143 |
The documentation explains it - a CEL expression which evaluates to 0.5 or higher is taken as true. So you can generate a user defined stopping condition from that. Bear in mind the details of how to evaluate expressions in a numerical framework as described by Opaque.
If the load acts on the duct wall then the duct wall is fundamental to how the load is reacted. This sounds like rigid bodies or FSI, depending on details.
June 26, 2021, 13:59 |
#28 |
AH
Rep Power: 13 |
Yes I have seen Opaque's reply, thanks to both of you. I will try this once I am back on computing.
if ( probe(Velocity)@MyPointofInterest < 0.5, 1 , 0 ) , where the point of interest is defined in domain. For the load it is just an area of selected elements on the air duct's wall. Just nee to apply 100 N on this these selected (within the mesher) elements. |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
the air velocity is not zero on the wall? | Li Rong | CFX | 5 | April 9, 2018 02:02 |
Calculating Wall Temperatures in CFX | Cthames21 | CFX | 8 | April 2, 2015 10:13 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
CFX heat transfer through house wall | AGrgic | CFX | 2 | August 6, 2012 08:39 |
